bluetooth motorcycle communication gadget.
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
Matagal ko na gusto bumili nito at ilang beses nauunsami, mapag usapan nga muna kung ano ang pede masabi natin dito..
Super Range“ride to rider” “rider to pillion” Bluetooth
interphone/hand free Bluetooth headset/ Bluetooth stereo music receiver for
motorcyclists and skiers
User Manual
You like to ride together;
wouldn’t it be great to talk when you ride?!
From now on, you can
talk with your motorcyclist friends by way of this new two way wireless Bluetooth
communication system, or you can chat with your pillion.
Maybe receive a cell phone call without pressing a button, You can enjoy your
favorite stereo music from your A2DP enabled cell phone or MP3 player or
perhaps listen to the audio navigation message from your Bluetooth enabled GPS.
With this New Super-Range Bluetooth, you can do all
these things even if you are riding or snow skiing!!!
All this hands free
functionality is contained within one self contained module that attaches to
the side of your helmet.
Main Features:
Maximum talking range 500 meters between two riders, real two-way wireless
communication between three riders by Bluetooth
system
Up to 120Km working speed
Up to 7 hours
talking time
Safe auto-receiving
cell phone calls
Advanced A2DP
& EDR Bluetooth profile
Stereo music/audio
function (transmits from A2DP enabled cellphone/MP3/GPS)
Wind noise DSP cancellation
Water-resistance, all weather,
Friendly for gloves
Read the manual
carefully before operating the system , and operate the headset strictly
according to the manual, otherwise performance might not be optimum
1. Contents
1. Contents ………………………………………….page2
2. Introdution ……………………………………….page2-3
3. Components of retail box ………………………..page4-6
4.Operation: ………………………………………..page6-14
2. Introduction:
We will describe this communications kit as B (Bluetooth headset) I (intercom) M (music)
This BIM can either be used for rider or for pillion.
This BIM can connect with four Bluetooth devices: a Bluetooth enabled cell phone, two BIM (two riders or one rider and one pillion), an audio source which with a built in or a external audio Bluetooth transmitter.
This BIM is a multifunctional device for motorcyclists and skiers, it can be used:
1) As a handsfree Bluetooth headset for cell
phone calls
While out riding or snow skiing, the auto answer feature of the internal Bluetooth profile enables safe automatic Handsfree answering of the phone call automatically. It also offers a call rejecting function.
—receive the cell phone calls even you do not need to press any button,
you just need to rider your bike as normal,
the process of receiving call will be automatic, after ring on of the call about 5 seconds; it will receive the call automatically. It also can offer rejecting call function.
2) As a two way wireless full duplex interphone
between riders or between rider & pillion
The Maximum communication range over a high clear line of sight path can reach 500m/1640ft! (This maximum range is not guaranteed).
Typical effective range in city is approximately 300m/950ft. Please note that actual range will
depend on weather conditions, terrain, presence of obstacles, i.e. a large vehicle, buildings non line of sight etc.
Unlike a one-way walkie talkie, which is only half duplex i.e. it can not speak and
listen simultaneously, the BIM offers real-time talking like a normal telephone.
It can connect with two other riders or connect with anther rider and his/her pillion.
The rider can chose which person to talk with
The working speed can be up to 120Km!
3) As a wireless Bluetooth music receiver and speaker, this BIM has EDR and A2DP profile ,
with EDR and A2DP profile it can offer another important function--- listening to stereo music from A2DP enabled cellphone,MP3 or navigation audio information from GPS(this MP3 or GPS should has a built in audio Bluetooth transmitter)
4) If your MP3, GPS did not have a built in audio Bluetooth transmitter, you only need to have a external audio Bluetooth transmitter (sometimes called an AV Dongle, you can find it easily in the market) to pair with them, then you also can enjoy this added functionality.
5) As the speakers of your MP3/GPS
If your MP3 or GPS is not Bluetooth transmitting enabled and you have not a Bluetooth AV dongle, the BIM also offers another method of listening to the stereo music/audio info--- the simple wired method. Plug the audio source directly into the BIM headset via the 3.5 mm stereo connection
Note: Different country may has different adaptor
Before using: Charging the BIM
Before using this device, Please charge the BIM main device with provided charger
We have provided you with the ability to charge the system via the USB port of your computer or if you are away on a trip, you can use the supplied Multi-voltage USB power adapter.
The charging cable has a small USB plug for the headset and the large USB plug for the computer or AC adapter; please
observe to correct orientation of the USB plug and socket before inserting
1) Insert the USB plug of the charging cable, into the USB small jack of the headset; you can either charging by
computer or AC adapter.
2) While charging, the red LED on the headset module will illuminate, when the charging is finished, the red LED
will extinguish.
Note: if you do not use the headset for a month or more, to protect the Poly-Li battery, please charge the headset at least every month. (The fault damaged by wrong charging will be not guaranteed).
Attaching and removing the BIM main unit on your helmet
With the clip, you can easily mount the main unit of the BIM on a helmet within 10
seconds without any tool and screw.
Step:
1) Find a best position on the left side of your helmet to put the clip
2) Insert the clip between the shell and the foam of the helmet
3)hang the main unit of the BIM on the clip
The clip
Insert the clip between the shell and the foam of a helmet
BIM mounted on a helmet
Attaching the two speakers and the microphone .
The success of the system depends on the careful positioning of the ear speakers directly over top of the ear canals. This will give the best signal to noise of the received audio.
1) To find the position of your ear canals, put your helmet on firmly but don’t do it up. Slide your thumb of one hand up between the inside of the helmet and your ear, with the fingers of that hand on the exterior of the helmet. Feel the ear canal in your ear with your thumb and then grip the helmet firmly between thumb and fingers of that hand, carefully take the helmet off BUT don’t move your thumb from its position inside the helmet. Look at where your thumb it! This place marks the centre of the ear speaker! Mount the Velcro pad to which the speaker will attach there, inside the helmet; check the other side for optimum ear speaker position.
2) Remove the protective backing of the Velcro and mount the Velcro pads in the correct positions, attach the two speakers on the Velcro inside your helmet, the speaker with short wire cord for left ear, the speaker with long wire cord for right ear.
The speaker with short wire cord the speaker with long wire for left ear cord for
right ear
Adjust the position of the microphone
Note: To reduce the external noise, you need to close the visor while riding,
and please adjust the position of the microphone to be right in front of your
mouth with the foam just touching your lips; the visor should cover the
microphone effectively!
(Minimizes wind noise contribution)
Correct position of the microphone Wrong position of the microphone
3) Plug in the positioned headset to the communications module and attach it to the side of the helmet.
4. Operation:
The operation is friendly and very easy.
Pairing with your Bluetooth phone for the first time
Note: You must have a Bluetooth enabled phone to “Pair” with the BIM
The rider and pillion pairing their headsets with their respective mobile phone should be at different time,
Before using the BIM, please familiarize yourself with Bluetooth function of your cell phone. Read the instruction manual that came with the phone so you can enable its Bluetooth function.
Before you can use this BIM in combination with your phone, you will need to “pair” it with your cell phone
for the first time. This usually only needs to be performed once with that individual phone however follow the instructions supplied by the phone manufacturer and save the “pairing” so it will be automatically connected when
this Phone and the BIM come into contact again.
1) Enable the Bluetooth function on your cell phone.
2) You must place the BIM in “Pairing mode”, this is done by way of a holding down the Power/Interphone key on the headset, until the red & blue LED flash alternately.
3) Begin the “searching for Bluetooth device” on the cell phone according to the phone’s instructions
4) when the BIM is discovered, the cell phone will display MOTOR PHONE select
this and accept the connection
5) The cell phone will ask you to input a password to enable this connection , when prompted input password : 0000 (four
zeros)
6) Your phone will confirm that pairing has succeeded. Note that the only light showing on the headset is now the blue one
and it will flash once every 5 seconds
Basic B.I.M Operation
Turn on press the Power/Interphone key for 6 seconds or so, until the blue lamp illuminate, promptly release the
Power/Interphone key, then the blue led will flash every 5 seconds
Turn off press the Power/Interphone key for 6 seconds or so, until the blue lamp long illuminate, promptly release
the Power/Interphone keythen the blue led will extinguish.
Increase the volume Short press of the V+ key
Reduce the volume Short press of the V- key
Connect the cell phone for some reason (e.g. In some regions of high RF strength), may the BIM will lose connection with the cell phone, a short press on the Phone/Play key, they will connect each other.
Safety Cell phone calls function
1) Receive a cell phone call automatically
When income a cell phone calls, you will hear the ring on the cell phone and about 3-5 seconds later, the BIM will receive the call automatically.
2) Terminate cell phone call
When you finish talking on the cell phone, a short press the Phone/Play Key, will terminate the call.
3) Reject a cell phone call
When income a cell phone call, you will hear the ring, immediately press the Phone/Play key within1 seconds, it will reject
the call.
4) Make a cell phone call
Dial a number on your phone as normal, ( but don’t do this if you are the rider only if the pillion!) the sound will be automatically heard in your headset
Notice: some phones, like Panasonic x70, will not send the audio to the headset, you may have to press the Phone/Play key to transmit the sound to your headset
5) Dial the last number Press the Phone/Play key 2-3 seconds, it will dial the phone number that you dialed last time. (Note: some cell phone do not support this function)
Interphone Function
Set up for bike- to- bike and rider-to-pillion intercom: pairing
Pairing is a one time process that is required for mutual recognition between a headset and other Bluetooth devices. once the two headsets are paired, they will retain paired whenever they are within range.
Please note that you can speak via intercom to one buddy headset at a time.
1) Pair with another rider
Simultaneously hold the power/interphone key on both matching BIM’s until the red & blue LED of the two pairing BIM’s flash, short press the power/ interphone key on one of BIM, a moment later the red LED will extinguish
and the blue LED then will flash briefly every 2-5 seconds, thus they have finished the pairing.
2) Pair with two other riders and chose which rider you will talk with
You can set up your BIM as a master device and you can pair with two BIM of other riders, then you can talk with two riders at different time.
STEP: Pair your BIM (BIM a) with one rider (BIM b) as 1) above, then turn off the BIM b. Pair your BIM
with another rider (BIM c). When finish the pairing procedure, you can turn on the BIM b. Initiate an intercom call (a short press the Power/Interphone key on your BIM), and you can talk with BIM c. However, a long press the Power/Interphone Key, you will hear a beep”du-du”, promptly release your hand; it will change the communication to talk with BIM b.
Note: for a,b,c three units, only two units could be set as master units, then the third(slave) unit
can not initiate an intercom talking, when one of the master unit change communication to talk with the slave unit, the slave unit will become master unit.
3) Pair with your pillion
If you only have paired your BIM with one rider, you also can pair your BIM with
your pillion.
Start/finish a interphone talk
Turned on your BIM, short presses of the power / interphone key then wait about 5 seconds, and then you will be able to communicate with another rider or your pillion. You only need a short press of the power/interphone key, to terminate communications
Note, to reduce power consumption, when you do not need to talk, don't keep your BIM on intercom state in a long time
Music function
1) Listen to stereo music from your A2DP enabled cell phone
Read the user manual of your cell phone carefully, if your cell phone is A2DP enabled, the BIM can receive the stereo music from the cell phone. Please note that only A2DP (stereo Bluetooth) enabled cell phone can offer Bluetooth music transmitting service. You can use the Phone/Play key to pause/play the music from A2DP Bluetooth devices.
2) Listen to music from some mono Bluetooth enabled cell phone
Almost all of Nokia mono Bluetooth enabled cell phone can offer Bluetooth music transmitting service, but some model of other brand cell phone can not offer this service.
We do not promise that the BIM will support music function for all mono Bluetooth enabled cell phones.
Step: confirm that your BIM has paired with your cell phone; play the music on the cell phone, and then you can enjoy the music on your BIM.
Note: for mono Bluetooth cell phone, you can not use the Phone/Play key to operate the music; you only can operate the music on the phone.
3) listen to stereo music from your MP3 by Wired method
the plug of the BIM cord (speakers & microphone cord) is 3.5mm,it will can be inserted into a major of MP3,insert it into your MP3 and play the MP3,you will can listen to the music from your MP3.
4) listen to audio navigation info from your GPS by Wired method
the way is same to listening to music from a MP3.
5) listen to stereo music from MP3 via external audio Bluetooth transmitter
If you have a external audio Bluetooth transmitter (it’s easy to find this product in the market), insert the plug of the transmitter into the jack of the MP3.
Pair the transmitter with the BIM according to the instruction manual of the transmitter. Play the MP3; you can listen to the music on your BIM.
6) listen to audio navigation info from your GPS via external Bluetooth transmitter
The way is similar with 7) above.
7) listen to stereo music from MP3 which with a built in Bluetooth transmitter
Please familiarize yourself with Bluetooth function of your Bluetooth enabled MP3 (this MP3 must has Bluetooth transmitting function). Read the instruction manual that came with the MP3 so you can enable its Bluetooth function. Pair the MP3 with the BIM according to the instruction manual of the MP3. Play the MP3; you can listen to the music on your BIM.
8) listen to audio navigation info from your GPS which with a built in Bluetooth transmitter
The way is similar to listening to music from MP3 which with a built in Bluetooth transmitter. Auto
Switch between different operations While talking by intercom or listening to music, if it incomes a cell phone call, the voice will be switched to “cell phone talking” state automatically. After the call has been hung up, the system will auto return to intercom talking or music playing state. While listening to music, short press the Power/Interphone key, it will launch an intercom talking after hanging up the call, the system will return to the music automatically.
Note: it might need about 5seconds to auto-return to “intercom talking” start after the “cell phone
talking” has been hanged up.
OTHER
FEATURES
·Digital Signal Processor (DSP) Technology for wind noise cancellation
·Excellent performance at speeds up to the legal limit with a full face helmet
·Easily mounts to all full face and open face helmets
GENERAL FEATURE
·Up to 7 hours talk time when connected to your cell phone
·UP to 7 hours time when listening to music
· Typical current consumption is 55 ~75 mA
· 500 mAh Li Polymer battery ·Standby time: 100 hours
·Charging time:~ 3 hours
·Chip brand: CSR
SPECIAL FEATURE
·All weather, rain and snow resistance
·Removable headset unit from the helmet
User Manual
All this hands free
Main Features:
system
Up to 7 hours
talking time
Safe auto-receiving
cell phone calls
Advanced A2DP
Stereo music/audio
Friendly for gloves
Read the manual
1. Contents
2. Introduction:
phone calls
| Component | Parts Number |
| BIM headset main part | BIM-001 |
| Clip for mounting the main unit | BIM-002 |
| Speakers & microphone & audio plug | BIM-003 |
| AC &USB Charger (AC110V-220V / DC OUTPUT 5V) | BIM-004 |
| User manual | BIM-005 |
will extinguish.
Step:
The clip
right ear
4. Operation:
zeros)
the call.
Interphone Function
your pillion.
Music function
OTHER
FEATURES
GENERAL FEATURE
·Chip brand: CSR
SPECIAL FEATURE
Last edited by auJHOtech on Fri 09 Jul 2010, 6:14 pm; edited 2 times in total (Reason for editing : too long to read)
auJHOtech- Moderator
Re: bluetooth motorcycle communication gadget.
wow..ang ganda nito perfect on a group ride ..specially sa back ride ..hehehe
Y I N G- Teenage Umang Hunters
Y I N G wrote:wow..ang ganda nito perfect on a group ride ..specially sa back ride ..hehehe
papa ying plan ko mag parating nito pag dating ni misis on July 20,,, brooommm san natin sisimulang gamitin ito... hehe sana matuloy na para ma testing, plan ko i bisniz so baka i post ko ito sa mcp, may nabalitaan kana ba na meron nito dito sa pinas?
pre wwala pa ako nabalitaan na ganyan ..better testing muna natin before natin i market ..para self tested natin ang item ..alam mo naman ang mga buyer mabusisi mga iyan kaya dapat masagot natin mga tanong nla ..korek maganda market nga doon na websiteauJHOtech wrote:Y I N G wrote:wow..ang ganda nito perfect on a group ride ..specially sa back ride ..hehehe
kaya mag plan na ng ride :) miss ko na din pagudpod..parang gusto ko mag long ride uli ..ipon mode ipon
ot- kamusta rehistro mo?
Ok na pre..pero wala p asticker nasa Pinsan ko pa din sia kasi nag lakad ..pina non appearance ko na ..teka pwede ba pag usapan Non appearance dito heheheauJHOtech wrote:ot- kamusta rehistro mo?
wait namin ang item na iyan sarap gamitin sa long and group ride iyan ..
oo naman.. kahit di ako makasama sa ride basta may ride ang QC-Bulacan chapter pwede ko ipahiram ito free, isine set up to sa helmet so double adhesive tape lang ang katapat.
panay na nga ang paglalambing ko ke misis para bilihan nya ko, nasa hongkong kasi sya at nasa mainland china ang supplier, US dollar pa ang bayaran kaya may transaction pa bago makuha. july 20 uuwi si misis, lets hope for this para matesting natin..
my beloved wife paid in bank our order of this unit,,, hintay nalang mai deliver at hopefully dala na nya when she get home in July20. yahooo...!! mahahalikan ko asawa ko ng milya milya at kelangan super romantic ang 1st night namin pag dating hahaha!!
HI
Peter,
Your 1000m Bluetooth communication has arrived here in the Philippines
last Tuesday July 20. I make a quick check and test it right away, I am so
DISSAPOINTED with it, I'm expected it to reach at least 700meters before the
signal drop down because as your Manual Instruction says it can be reach
1000mtr range with out obstruction, but it only allow me 100mtrs in open road,
then when i test it in a busy road and it block us with 1 vehicle, the signal
start droping out hearing a popping sound. The maximum range in an open area
reaches us 150mtrs with clear sound and when it reached 200mtrs, popping sound
start to hear and intermittent voice hearing will start to occur, and when it
reached 250mtrs it will totally dis engage the communication. I gave you a FAIL
grade in evaluating your product 1000m Bluetooth, though it can be use for the
driver to pillion and BIM to personal phone and bluetooth gadget it wont go any
further from that. I suggest you change the specs of it. I plan to have a short
video in how i actual test your product and post it in the internet like
youtube and product blog.
Joseph Vergel B. Manalo
Philippines
Peter,
Philippines
Page 1 of 2 • 1, 2
Similar topics» bluetooth motorcycle communication gadget.
» Welcome to Kinnetik Communications
» Cordless Detecting with Bluetooth
» OBDII (SORRY!!!) bluetooth transmitter
» Bluetooth Handfree Car Viewer
Page 1 of 2
